Re: Car cranks but won't fire, but eventually will
When you turn the key to start it, the car will keep cranking even when you let go of the key, this is normal & some crossfires do this. i have 2, one does this the other doesn't & it's totally normal. You can have the dealer fix this theres a TSB if it annoys you. It doesn't annoy me anymore.
As for not starting and long cranking times before starting, check the Fuel pump. As mine also had this problem & the Fuel pump needed to be replaced & now its starts right up.
