Old Sep 16, 2010 | 06:03 PM
  #61 (permalink)
mr-lama's Avatar
mr-lama
Default Re: F*** this car and chrysler
Originally Posted by bmorgan
Anti squeak is usually in the form of a grease. You can pick it up at any auto parts store in little single use packets. You want to put it on the back of every brake pad. What causes the squeaking sound is the metal plate on the back of the brake pad vibrating against the metal on the brake caliper under braking conditions. It is not from the pads themselves. Hope this helps.
Helps a ton.
I had some spray on stuff I had used before, but I don't think it was super effective, so I went and bought some actual grease that I had to brush on. It said apply liberally, and since it was a grease I could put it on thicker than the spray.
Anyway, took it out and no squeak at all. As long as the stuff sticks and doesn't wear off, I'm happy. Thanks man.
