Old Sep 18, 2010 | 01:39 AM
downwardspiral's Avatar
downwardspiral
Default Re: Front Plate Bracket
You can probably get away with mounting the plate to the lower grilles using through bolts with washers behind the grille. You can use brass tubing or something as a spacer to keep the plate rigid.
