Old Sep 19, 2010 | 03:08 PM
SpeedDemon's Avatar
SpeedDemon
Default Re: Car won't pass inspection
Have you checked the fuses, there is one fuse for each headlight. So check the four fuses, they are on the drivers side end of dash. remove the panel cover and check them. If it is a blown fuse you may have to figure out what caused the blown fuse or you may be lucky and a new fuse will not blow.
No, I didn't check the fuse. I don't know anything about cars - I'll definitely check them. I hope that's the problem. Thank you!
I took my car over to AutoZone but for some reason the 'check engine' light was out and they said they couldn't check it unless it was on. I'll take it back when it comes on. If it doesn't come back on, I'll get it inspected once I get the light fixed.
Thanks, everyone.
