Can you post some pics of the splice block and bolt that required tightening please?
I'll have to do that tomorrow. However, in the meantime I can tell you exactly where it is.
It's on the drivers side of the car, in the engine compartment. All the way in the back there are 2 relays, one yellow, and one black. Pull the relays and right behind them all the way to the left, towards the passenger side, is Splice Block 100. . . bolts are right on top. I think they range from 8mm to 4...
Don't worry about removing the relays and replacing them in the right way.... I worried myself and then found that they only plug back in one way. . you can;t go wrong.
