Anomaly 2004 Coupe
Old Sep 23, 2010 | 08:18 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Anomaly 2004 Coupe
Can you post some pics of the splice block and bolt that required tightening please?
Old Sep 23, 2010 | 08:34 PM
projectmangaler's Avatar
I'll have to do that tomorrow. However, in the meantime I can tell you exactly where it is.
It's on the drivers side of the car, in the engine compartment. All the way in the back there are 2 relays, one yellow, and one black. Pull the relays and right behind them all the way to the left, towards the passenger side, is Splice Block 100. . . bolts are right on top. I think they range from 8mm to 4...
Don't worry about removing the relays and replacing them in the right way.... I worried myself and then found that they only plug back in one way. . you can;t go wrong.
Old Sep 23, 2010 | 08:41 PM
Thanks for the great description. I wonder if the relay on the right had worked its way out of the connection block??? There is no hold down clip for this relay and it is the relay that you connect the piezo buzzer to for the alarm chirp mod. Has this mod been done to your car previously??
Old Sep 23, 2010 | 08:53 PM
Hmmmm... well no mods have been done that I know of. . .
As for the relay being loose, it may have been at one time. However, I have tightened or tapped it at least 5 times over the last months when I would go over the car, hoping it would start....
Either way, I am positive that the relay itself wasn't the issue. I am 100% positive that it was the bolt right behind it.
Old Sep 23, 2010 | 08:58 PM
OK ...the main thing is you found it. Great work.
Old Sep 23, 2010 | 09:30 PM
Glad you were able to fix the problem. FYI, just in case your ESP/BAS light comes back on, check your tire pressure(s). We have found that on my wife's Xfire (2004 coupe), the ESP/BAS light will come on if the tire pressure(s) are low.
PNA
Nov 12, 2020 04:44 PM
Soma
Dec 14, 2015 07:52 PM
Snake Eyes
Sep 28, 2015 08:55 PM
XWynd
Aug 11, 2015 03:45 PM
itsky
Aug 9, 2015 07:39 PM
