Re: Oil Sending Unit and Headlight Harness...Among Other Issues
For the lighter shorting out make sure there is nothing inside the socket assembly, also check to see if any thing is bent inside the socket, also check to make sure your lighter element is not bad, the socket is just a positive and ground set up so there is not much there to short out, but enough.
