The hood MUST come off for proper installation of the liner - this is NOT a big deal! Why does the hood have to come off? It comes off because the liner must be installed with spray adhesive and if you don't mask off areas then the glue will get onto places you don't want glue on, such as the windshield, the engine, fenders, cowling, etc. It would get VERY messy. Plus gravity will work against you and your arms will get tired trying to work with them above your head. Ever try cleaning the ceiling fan blades? Your arms hurt after a while, right?
My liner is not stiff like the original, it's made of a SUPERIOR material and installing it with just the plastic hood pins and no adhesive is
not recommended. It will SAG in areas not held in by clips! If you have a helper then removal of the hood and installation back on the car with the new liner will take about an hour. You can lay your hood on a large worktable or a plywood on a couple of sawhorses, cushioned with some old blankets or sheets to protect the paint. I include instructions for both the liner and the decals, and in those instructions I provide my AT&T Cingular cell phone number if you need my help during installation. So far no one has called needing my help so it's not impossible to install my liner!
HE HAS A PATTERN FOR THE CROSSFIRE COUPE NOW BECAUSE I SENT HIM MY ORIGINAL AS A TEMPLATE.
OTIS
Attachment 19186
Attachment 19187
Attachment 19188
Attachment 19189
Attachment 19190
