Old Sep 27, 2010 | 01:07 PM
  #90 (permalink)
MAXIMUSQUO's Avatar
MAXIMUSQUO
Lightbulb Re: I'm building another one... Supercharged V8 Part Deux!!! :D
Max, Can you confirm that the CLK55 rear end will bolt right in? I will soon be adding a supercharger and need to know my options if I start breaking things.
Hi Lantana,
the rear end you call is diff and will fit from CLK 55 AMG W208 and E 55 AMG W210 to the Crossfire with no mechanical work on body. The MB part# is A208 350 20 14 but you will need the both axis too, the part# is A208 350 07 10. The axis from CLK 55 AMG W208 will fit to roller bearing in Crossfire too.
The next point is that the rotor shaft from Crossfire is different than from MB like CLK or E class. So you will move the wheel from diff too!
regards V8Max
