Re: Which mounting holes for front camber bolts?
Really? I changed all the camber bolts on my car after lowering it and it specs out perfect to factory specs.
When you lower the car you increase negative camber in the rear and increase postivie camber in the front. In the front, I used four bolts (two on each side) to increase negative camber. Toe is adjusted with the tie rods not with the bolts.
In the rear I have the adjustable camber kit.
