OK, This is the E-Mail I received from TVT on this topic:
Glad everything arrived safe. The bolts are installed in the front most part of the lower control arm. They are inserted the same way they are removed. You will need to put the indented part of the washer towards the inside of the car to adjust for positive camber and the opposite for negative.
Hope that helps.
Once again I have E-Mailed TVT to double check so we can get make sure we have the correct info. But I installed mine as he stated in the E-Mail he sent me.
Thanks again to TVT for all the help!!!
2nd E-Mail (Also on a side note TVT has respond super quick to all Of my questions!!!):
The alignment shop is correct. You will only need a set for the rear spot if your caster is way out. The bolts will only correct for +/- .3 degree. If your caster is in spec, then you should be fine.
Thanks again to TVT for the help. I hope this helps everyone
