Old Sep 28, 2010 | 02:43 AM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Huffer Won't Huff.....
Originally Posted by Semi
....however I replaced the IC pump myself with no problem (or at least I assume so... I'm very experienced in wiring electronic devices, so I doubt I screwed up the connections to the pump) Is "moving the heat exchanger" something I could do on my own without taking everything apart?
I'm willing to try anything that doesn't include me losing more $$
I've been told that prayer works... but I'm not quite to that point yet.
If you installed the pump yourself - disconnect the "hotwire" going to the pump and leave the ground wire alone.
Make a jumper wire and connect one end to the positive lead on the battery and the other to the positive lead wire gong to the pump.
Listen to hear if the pump runs.. If it runs - squeeze the output hose to see if coolant is flowing... could be you didn't prime the pump with coolant and perhaps it burned up??
If your IC was leaking - you would have an obvious low coolant level and possible a sputtering engine.
If all is OK - then change you IAT sensor - $30 and 15 minutes
