Re: FS or WTT: Complete SL55 intake setup with TVT tubes
what do you mean by "the way it sits"? the way it mounts on the rubber mounts on the engine or the way it sits without the oem center cover? if it is the mounts try adj. them. if its the center cover you can cut the tabs off and rotate them to fit in the airboxes and epoxy them back in place. just an idea
