Old Oct 6, 2010 | 11:09 AM
6ʇɹsǝɹıɟssoɹɔ's Avatar
6ʇɹsǝɹıɟssoɹɔ
Default Re: That F%^**&*## Washer (Sprint Booster)
Originally Posted by Bill F
Option 2
Remove the kick panel on the console. This is the panel that is to the right of your foot as you sit in the car. First remove the screw on the side of the console where the vent is. After that is removed remove the second Phillips screw holding the side panel on the console in place. Remove the drivers side of the console. Now look back above the gas pedal and there is the plug. Squeeze the sides to release the locking mechanism on the plug. Unplug and insert the SB. Replug the plugs with the SB in line. Replace console side and screw and then the vent and screw and now you are done! No pedal removal or nut to drive you nuts. Simple.
thanks for making this a 3 min job love the booster $$
