Old Oct 6, 2010 | 02:37 PM
  #43 (permalink)
KBoyd's Avatar
KBoyd
Default Re: Throttle Body Reset?
Originally Posted by 6ʇɹsǝɹıɟssoɹɔ
i installed sprint booster today <3 it. then i read on here i should reset throttle..
so i reset and fricken check engine light comes on is this normal?. I don't have my code reader at work to check code.
I had the same issue. Do you have throttle control? If not, you have the plug on backward. If you have throttle control, which I did have, but I did have the CEL. I disconnected my negative side of the battery for 1 hour, re-connected and that cleared the CEL.
