Old Oct 8, 2010 | 01:55 PM
LantanaTX's Avatar
LantanaTX
Default Re: Stronger Differential and axles available
This looks very promising! Here is a email I just received from Kevin Bird:
I will have to check this carefully, but if the number is A2103531501, then we could be in business.
One of the three new versions we have commissioned with Quaife, which are due into stock later this month will work with that differential.
Moreover, we have records of ratios 3.27, 3.47 and 3.07 available for that Quaife unit.......
When I've had a rest from this weeks heavy workload, I will recheck my data, and ask you to carefully confirm the number on the diff case.
If it all checks out, then I will ask Andy to bring his SRT6 down when we have the Quaife stock, and with a bit of luck, we're in business.
Regards, Kevin.
Rudy, Can you confirm the part number?
