Old Oct 11, 2010 | 04:21 AM
Black03AR's Avatar
Black03AR
Default CAB Module / ABS Pump
Hello,
I was wondering if anyone here has ever changed their CAB module or ABS pump and what the easiest way to do this is.
The CAB is held on to the pump with 4 torx screws, but I can't get to one of them, because there is not enough room between the fuse box and the screw head to undo it.
Not sure if there is a way to "move" the fuse box out of the way to reach the pesky screw or if the easiest way is to remove the whole pump.
Any advice would be most appreciated, I hope to attempt this next weekend.
Regards
AR
