Old Oct 17, 2010 | 10:32 PM
pizzaguy
Default Re: original battery since 2004 is death near
Originally Posted by mdotoli
My Crossfire still has the original battery since 2004, I have 18k miles.. is death near? Should I just replace it, any warnings signs I should be looking out for.. What type of battery should i get..
thanks
Mike in Gastonia NC
It appears that miles mean little - but YEARS mean a LOT! I got a battery that meets the specs at O'Reilly's for $89 a year ago. It's a LITTLE shorter than the original, I have a piece of heater hose in there as a shim to keep it from moving around.
Mine is a SuperStart 48-72 or 48AGM.
A bad battery can leave you stranded, and the weird thing is, when you turn the key to "start", the engine will turn over and start, then die right away. Does not SEEM like that would be the battery - but it can be! I saw it happen.
Go get a battery!
