Re: I'm building another one... Supercharged V8 Part Deux!!! :D
It is very hard to nail down a cost for this conversion becuase there are many vairiables. First of all you have to locate an engine and the prices for these are all over the map. Once you have the engine, did it show up with a complete engine harness that hasn't been cut? Was the ECU with the engine or do you have to source that also? While any 113 V8 will work does it need additional work and parts because it doesn't have other Crossfire compatible parts such as the oil pan, pump and pick up? The ECU's vary as well. It may be nessessary to reflash the firmware to a differenct version to work with the Crossfire componets such as the shifter. There all kinds of issues that can pop up which can vary the cost.
