Originally Posted by tighed1
I think your running rich because your at 4000'
I also believe the 4600 ft elevation has something to do with it.
Which code 3 are you running
Running the 2nd Gen Code 3.
with the 181 crank ? How much boost ?
Max boost is 19 lbs (or so) varies +/- with weather.
How much boost are you running on the 192 crank ?
192 pulley I think (car is in the shop) is 'round 18 or so.
Do you think your exceeding the rpm rating of the supercharger ?
When my S/C went before (seized) I was driving very hard, constantly accelerating and exceeding 100+ mph speeds for a good 30 miles or so. When I turned off the highway a got about 3 or 4 miles then the S/C locked up. I believe that it was due to the fact that I ran at higher RPMs for that extended time that caused the failure.
But that's just my 2 cents!
Comments anyone?
Yes bring it down here and I'll put on my DR's and see if we can't seize up another while getting you way into the 11's. I'll volunteer to drive.
