Re: Standard, LED, and HID Lamp Solutions and Numbers
Hi:
You state that the parking front "eyelid" bulbs are the hardest to change on the car but can be removed by turning the gray bulb sockets with needlenose pliers. However, how do you then remove the socket from the headlamp assembly. On my SRT6, there is a plastic cover on the back of the headlamp assembly that prevents easy removal of the bulb socket once it is loosened with pliers.
Thanks for the help.
JM Lasker
