Old Oct 27, 2010 | 03:56 AM
kingkub57's Avatar
kingkub57
Default Re: water leak, wet headliner
If the leak is showing up on your headliner just behind your head area then it could be a bad seal on the body where the door glass makes contact, or may even could be in the roof rail area under it, the seal may have cracked due to body stress. When mine did it, it was the door glass/body seal, and it took over 4 times to fix it at the dealer under warranty it was an 04 coupe. Hope this helps.
