Old Oct 27, 2010 | 09:45 PM
onehundred80
Default Re: aiming high beams?
Originally Posted by Crossfire725
If possible how can you aim you high beams. I installed hids in them as well as the lows an I wanna lower the hight so I can drive with all lights on. Thank you
If you want to lower the high beams then the low beams will be really low. But that may be acceptable to you.
If you installed HID's then a bulb or bulbs may not be correctly installed and this could make it aim high or low.
Why you would want all the headlights on all the time is a bit odd, cars with a lot of light from the headlamps are a pain when they come toward you, but as you said you do not care.
You had better hope the PO agrees with you when he comes toward you, somehow I doubt he will.
