aiming high beams?
Old Oct 25, 2010 | 05:47 PM
Crossfire725's Avatar
Default aiming high beams?
If possible how can you aim you high beams. I installed hids in them as well as the lows an I wanna lower the hight so I can drive with all lights on. Thank you
Old Oct 25, 2010 | 06:03 PM
bmorgan's Avatar
Default Re: aiming high beams?
No, the high beams cannot be adjusted.
Old Oct 25, 2010 | 06:06 PM
Dammm really.
Old Oct 25, 2010 | 06:09 PM
bmorgan's Avatar
Originally Posted by Crossfire725
Dammm really.
LOL.... Really! Sorry!
Here is what the service manual says.
HEADLAMP ADJUSTMENT
A properly aimed left and right low beam headlamp will project the center of the low beam hot spot on the alignment screen below the horizontal center line and 152 mm (6 in.) to the right of headlamp center line. The high beam headlamps cannot be aligned. The high beam pattern should be correct when the low beams are aligned properly.
To adjust headlamp alignment, rotate alignment screw to achieve the specified low beam hot spot pattern.
Old Oct 25, 2010 | 06:12 PM
Dammm. Ok well thank you for the find and info. Guess gonna drive with hid high beams an blind the world ahahah
Old Oct 25, 2010 | 07:49 PM
Mike1118's Avatar
Not good. All you're gonna do is **** somebody off. They just may spin around and follow you just to key your car..................or just shoot ya!
Old Oct 26, 2010 | 07:09 AM
singerron's Avatar
Maybe you need to get the low beams adjusted. The highs should be ok after that.
Old Oct 27, 2010 | 09:12 PM
nox1s's Avatar
You're kidding right? What a great way to cause an accident.
Old Oct 27, 2010 | 09:45 PM
If you want to lower the high beams then the low beams will be really low. But that may be acceptable to you.
If you installed HID's then a bulb or bulbs may not be correctly installed and this could make it aim high or low.
Why you would want all the headlights on all the time is a bit odd, cars with a lot of light from the headlamps are a pain when they come toward you, but as you said you do not care.
You had better hope the PO agrees with you when he comes toward you, somehow I doubt he will.
Valk
Jul 12, 2021 09:49 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Oct 1, 2015 01:42 AM
ala_xfire
Sep 28, 2015 05:51 PM
JEFASOLD
Sep 28, 2015 12:10 PM
