Re: Center Console Top Vent Molding Rattle
Yep gotta take the middle piece off first. If you search for console disassembly instructions you should find them quick. If I remember correctly you got to take the radio out, then unscrew the middle trim (screws above radio) then you will see the ones for the top vent. Without removing, not to sure. Could just try to push around the edges and shift it up/down might find a position it sits in better
