Center Console Top Vent Molding Rattle
Old Oct 21, 2010 | 02:52 PM
gherrin's Avatar
Question Center Console Top Vent Molding Rattle
The center console top vent molding is rattling and I have attempted to remove by prying under the molding but stopped due to fear of breaking. Can anyone tell me how to either tighten this section of the console without removing it or offer any other suggestions.
Old Oct 24, 2010 | 06:55 PM
HyprLtH20's Avatar
www.CustomCrossfire.com
Default Re: Center Console Top Vent Molding Rattle
I think there are 2 screws on the bottom side holding it in if im not mistaken.. You would have to take the lower trim off to get to them
Old Oct 28, 2010 | 06:37 PM
Airscape's Avatar
Yep gotta take the middle piece off first. If you search for console disassembly instructions you should find them quick. If I remember correctly you got to take the radio out, then unscrew the middle trim (screws above radio) then you will see the ones for the top vent. Without removing, not to sure. Could just try to push around the edges and shift it up/down might find a position it sits in better
Old Dec 24, 2012 | 11:20 AM
JHM2K's Avatar
I've developed a slight rattle on my vent as well... left side is loose, right side is secure. After I tear the dash apart, I will use a grade-8 bolt with Loctite Red.
Old Dec 24, 2012 | 11:41 AM
Oops, never mind, deleted by me!
Old Dec 24, 2012 | 11:43 AM
JHM2K's Avatar
Did I just respond about the right side top dash was loose on your car? If so, then I suspect for sure your dash was off. Might be a few more loose screws/bolts in there. Going to be a time to find them all if its true.
Not mine, that's another thread I think. My dash has never been removed... it's just the A/C vent that has jarred loose over time.
Mackel
Oct 16, 2015 09:03 AM
nataliefs
Oct 5, 2015 01:03 PM
55chevy
Sep 13, 2015 07:38 PM
jaesa
Sep 7, 2015 01:50 PM
williammt
Sep 6, 2015 11:23 AM
