Old Nov 1, 2010 | 03:33 PM
BoilerUpXFire
Default Re: 19" Mercedes AMG Rims on all four wheels?
Originally Posted by Jesus_Christler
So, given you would be running the same heights and widths, would it be better to get rims with different offsets? Or get wheels with the same offsets and use hub-centric spacers on one axle (rear?)
Jesus, IMHO adding spacers is always the last possible resport, and then, only use a good quality hub centric ones. Any time you add in a piece, in this case a spacer, instead of having the correct offsets, you are just adding something to the list that can fail, not to mention, instead of the wheels being one piece, there is another 'layer' between them and the hub. Anytime you can get wheel to match hub directly, you want to go this route....
