Old Nov 1, 2010 | 07:24 PM
rcompart's Avatar
rcompart
Default Re: 2-Din Head Unit Kit
Originally Posted by HyprLtH20
All I am talking about is a new trim piece to support a double din. $300-$400 is outrageous for that. Im thinking more like $150 or under and thats including the trim for around the cup holder area too. Im not sure why you were unable but I know I certainly am. Quality will not be an issue
I have taken plenty of heat from you in the past so I knew Id be hearing from you on this one too
I'm not ever trying to give you flack, just constructive criticism and if you think it's catching heat from me, then my apologies. All I'm saying is I've done this before and I've found that some stuff is easy, some stuff is hard and some stuff makes building the pyramids look like a walk in the park. With all the time and money I put into building these with Jonny, I can assure you that unless you're privy to some pretty fancy equipment, these are not going to be easy but good luck and prove me wrong.
