Old Nov 2, 2010 | 09:40 PM
pizzaguy
Default Re: Now I need more advice
A limited auto Roadster with 32,000 miles? Sounds like my car!
Well, there are a lot of little things:
Is there oil leaking from the valve covers? Is the back window glue failing? Is there rust starting on the bottom of the doors? (Probably the biggest one!!)
But nothing I can think of as deal breakers. The leaking oil thing is easily fixed, as is the back window.
I'd do a search here for a thread called "stop the rust while you can". That is the only thing I can think of that I'd worry about OTHER than the normal stuff you check on with a used car.
