Re: Carbon fiber key fob
Hunts, that is the piece I am referring to. The piece that covers the heat/ac control, the switches, and radio. The problem I ran into is the thing is so darn complex that the vinyl wants to return to its original position. The only set up that seems to get it right is the process used by SRT-Six, Karl. I do not believe that he uses the 3M process.
When I saw Max's car, the lip that is immediately below the switch had an area in which the 3M had pulled away from the panel. I also had this happen and tried applying three different ways. Good luck! Make sure your piece is very clean and use the 94 tape primer. That should help you as well.
Jason
