Old Nov 5, 2010 | 02:40 AM
jsaredwings's Avatar
jsaredwings
Default Stuck in Park, check engine
srt6 Auto
on my way home i had noticed it had lost power and thought it might have just been the water pump(needs replacing) for the SC however normally that powerloss last only a couple minutes. so i pulled over and shut the car off, after restarting i went to put the car in drive, but it was locked it park and the check engine light came on. I had to manually unlock the shifter and was able to drive home in limp mode, would not go past second. All the fuild levels are normal.
I noticed two things, first when starting the car, there is a slight delay when i turn the key. not much but it something new. maybe 1/2-1 second delay to turn over
Also, i had only been driving for 10-15 minutes but when i was trying to figure out what the problem was and when driving home i noticed that the engine temp was a little higher than normal.
I do not yet have any codes as my friend has the machine and i probably wouldnt get them for a couple days, hopefully by the end of the weekend.
So if anyone has experienced this or knows what the likely problem is let me know. thanks
