Old Nov 10, 2010 | 01:51 PM
Never_satisfied's Avatar
Never_satisfied
Banned
Default Re: H&R Sport Springs or Eibach
Originally Posted by steveb8699
So do I need these for both the front and the rear? It does not look like TVT makes them for a Crossfire, however, they do make them for an SLK55. Maybe this would work?
I've researched a bit and here are the websites;
TVT
TVT Design, Crossfire/Mercedes/Genesis Performance Parts - SLK55
Speedybnz
Shop Page
TVT Design, Crossfire/Mercedes/Genesis Performance Parts - Crossfire_suspension - Crossfire Page/setup
You will need one set of the eccentric bolts for front camber adjustment that you can purchase with the set of Adjustable Camber Arms. I then went to my local Mercedes dealership and picked up another set of eccentric bolts for the rear to adjust the camber. Even with all the bolts in the front you may still only get close to factory specs. The lower the springs put your car the further away from factory specs you will be even with all these parts. I went with an Eibach set so I could be as close to factory specs as possible. Most of the other spring sets drop the front even lower. I also went with Koni's adjustable shocks. Just my 2 cents!!!
