Old Nov 28, 2010 | 05:31 PM
kolevski's Avatar
kolevski
Default Re: Small Problem :(
Thank you for all your responses guys you've really helped me
Out. Bill with the Kiwi wifi unit was that able to give you AFR figures? I know Steve said our car has a narrow band but as you can see I'm trying to get a reading the easiest way ( through the OBD II) if possible. If not the second unit you have that requires to install a bung does that come with software and ability to use with a laptop like the base line zetronix unit? Or does it come with it's own monitor?
Evan I remember when were chatting we said it may run rich rather then lean or maybe my memory serves me wrong! But if that's the case the delay in shift may be due to my car being flooded with fuel...!! I emailed Rob I'll see what he Thinks of the issue.
