Originally Posted by kolevski
Thank you for all your responses guys you've really helped me
Out. Bill with the Kiwi wifi unit was that able to give you AFR figures? I know Steve said our car has a narrow band but as you can see I'm trying to get a reading the easiest way ( through the OBD II) if possible. If not the second unit you have that requires to install a bung does that come with software and ability to use with a laptop like the base line zetronix unit? Or does it come with it's own monitor?
Evan I remember when were chatting we said it may run rich rather then lean or maybe my memory serves me wrong! But if that's the case the delay in shift may be due to my car being flooded with fuel...!! I emailed Rob I'll see what he Thinks of the issue.
if im correct you have to have the bung welded in and a separete O2 sensor installed to read wideband afr. if you look at the plx website you can order a gage that reads the sensor for you. im guessing bill was reading everything off his ifone and im not sure thats available to you in aussie.
the zeitronix is a great unit its what i use in conjunction with the dashdaq. i know someone had a complete setup for sale a little while ago not sure if it sold. maybe rob can make you a christmas steal!
looks like rob has the zt-2 without a readout for 279$ saw he had a complete unit for sale in 09 used maybe he still has it
