Re: Filter O-ring failure leading to Serp belt failure
Originally Posted by shaverj
Changed the oil this weekend, myself as I always do, tried a new filter brand (bosch type) STAY AWAY FROM THESE) I should have known better but when I replaced the orings I noticed the largest one did not fit snug on the housing right out of the box. Took it for a test drive anyway and everything seemed ok.
On my way to work my battery indicator came on, I have about 50,000 miles so I figured it was probobly letting go, just turned off all the lights/radio and didn't have too much farther to go.
The first turn off the expressway I almost lost the car in the guardrail as the powersteering was surprisingly gone! At this point I know the serpentine belt is probobly toast, only another mile to go so I figure I'll limp to the nearest parking lot.
First Traffic light, the temp starts to climb and I smell oil. I immediatly start cussing that damn O-ring lol. Lifted the hood in the parking garage and the serpentine belt was gone but replaced with about 2 quarts of fresh 0w40.
On to the questions...
- Anything special about replacing the serp belt I need to worry about?
- Can I jump start this car if needed, a search seemed to indicate it wasn't a wise?
- Where can I get a decent filter with reputable O-rings?
- Any recommendations for getting that oil out of my engine bay?
Previously I was using FRAM
but their paper filters are crap, I actually went to 4 parts stores and even the dealer which all produced similar paper (or maybe its fleece) filters. grrrrr I want the silver one that looks almost metalic that came with the car, very heavy duty and bound much more.
Thanks in advance.
Where did you put the O-Rings? They are supposed to fit in the grooves not go under the flat face or any thing like that.
This has been covered before, it is not the filters fault, it's probably yours.
