Re: Air Pump Problem - (common)?
15 minute fix. Remove RCM module, pry open box, clean obvious culprit relay with point file or emerycloth, reassemble, drive car. Done.
I'm guessing you've been there/done that? That would beat paying $100 deductable @ Chrysler. I probably should look into what a new RCM module cost in case I need to replace it.
I gotta ask with a screen name like tunaglove, are you a freelance gynecologist?
