Old Dec 2, 2010 | 06:28 PM
oledoc2u
Default Re: Air Pump Problem - (common)?
Originally Posted by Steve Hellums
The one I bought new has the SL55 on it. The one thats having the air pump running problem even with the key off that I bought from Jeff Cobb has a single NeedsWings intake on it. I'll probably pull the RCM in the next day or two, I'm sure that the contacts are probably stuck on the relay.
when people install the dual cai, there is a kit for moving the power steering lines...just thought maybe this had been done...sometimes they don't get the lines on quite right, or tightened correctly...but, it has a single, so never mind....hope it works out for you...I was down your way a few days ago...
