Originally Posted by SRT6 Gang Member
If u exceed 19+ psi boost again, your a/f will not be safe. The colder it gets the easier it is to exceed..
prolly wont happen. with the c3 19 lbs is the most i have ever seen. 11.9 at 18 lbs is right were the car should be. climbing above 13 afr would take more boost than my c3 can produce. 20+ reserved for the 181,185 group!
also common sense has to be used. temps in the 30's or 40's with summer tread isnt a good thing and if i wasnt datalogging to see what the mods did to my afr the car would be in the garage. racing has halted here for the winter and wont reopen till the spring. then 60* weather is were the car really shines and 19 lbs boost is max at best
