Old Dec 7, 2010 | 08:36 PM
James1549
Default Re: Fog Light Install on 06 Base
It has been done many times here. You can use the factory switch to make them work. I would stick with OEM if you can get them affordable. It is not a hard job, there are several ways to hook them up to work with the factory switch. Someone here can chime in that actually accomplished the job.
Personally, I would use a relay and have them come on anytime the running/parking lights are on. That way no need to run a wire into the cab.
Good Luck, James
