Fog Light Install on '06 Base
Old May 13, 2012 | 11:47 PM
lildaddym's Avatar
Default Re: Fog Light Install on 06 Base
Originally Posted by Mrmiata
Since this thread popped up just wanted to toss .02 in. Recently heard of a couple different people getting pulled over for fog lights on without inclament weather here in Oklahoma. Might want to check your local laws before wiring in as DRL's.
Interesting...I can't imagine GM delivering cars to OK that DON"T have the DRL, just because that's the law there...wonder if there is any way to turn them off on those Corvettes and Firebirds, for example...
Old May 13, 2012 | 11:49 PM
lildaddym's Avatar
Default Re: Fog Light Install on '06 Base
So, just so I understand: What's the procedure for using existing fog lamps as DRLs? Probably can do that in Texas...specific instructions with photos and parts used/needed would be great!
Old May 14, 2012 | 06:49 AM
Mrmiata's Avatar
Actually one guy that was stopped.. they were his DRL's (fogs) on a factory setup. He was told he needs to get that fixed.. LOL. Guessing the laws reguarding them really need to be updated. But still doesn't change the fact if they want to be **** they have a "reason" to pull you over. I'm sure with a court date and time missed from work you could beat it in court.
Old May 14, 2012 | 11:33 AM
gunner1374's Avatar
Factory fog lights can be turned off. It is illegal to run fogs and headlights at the same in Oklahoma and probably other states as well. They can push the issue if they need a reason to pull you over. I have been once, years ago, but still drive with them daily and no issues.
Old May 14, 2012 | 11:36 AM
gunner1374's Avatar
I plan on running a set of projector fogs in mine. I like the look better than the square factory fogs. Why would they use square when headlights are round? Just doesnt look right IMO. I will run them off of the switch inside just to be sure of no future issues.
Old Oct 30, 2014 | 12:07 PM
darf's Avatar
Has any one tried installing universal fog lights by adapting the openings where the lights are located? Probably a no-no for crossfire purists like myself.
Adrian_X
Nov 9, 2017 08:49 AM
jgreen
106
Sep 18, 2017 11:46 PM
pioneer4x4
Jul 21, 2015 10:35 PM
KwehCat
Jul 16, 2015 04:48 PM
shawnwatson9493
Jul 9, 2015 11:47 PM
