Old Dec 10, 2010 | 11:35 PM
splinter's Avatar
splinter
Default Re: Transmission Fluid
Originally Posted by cassidyrj1
Hey guys not sure if you know this but the trannys we have, have a protective overflow drain. If you do end up putting to much fluid in the tranny during use and when it becomes hot it will dump the excess fluid.
Virtually all automatic transmissions have a vent through which they equalize case pressure.
Can’t in good conscience recommend establishing proper ATF level via “dump[ing] the excess fluid.”
