Thread: Stereo?
Old Dec 16, 2010 | 05:39 PM
blackcrossfire07's Avatar
blackcrossfire07
Default Re: Stereo?
Originally Posted by itsky
I know this is an old thread, but I'm looking at replacing the stock unit in my coupe. Sounds like this particular unit is simple to install? Did you have to get any other tools? Sub-woofer work fine with the amp? Did the radio come with tools to take out the stock unit?
The stereo looks nice, but I would like to have a USB port on the front to charge my Zune and it doesn't appear that this particular unit has this option. Has anyone else installed an aftermarket stereo that does not require a wiring harness and has a USB port on the front?
My unit does not have a USB port in the front. You can pick a unit that has a front USB port. I am pretty sure all Blaupunkt stereos are plug and play with a base coupe. All that is needed is an antenae adaptor and a key to slide the old radio out. If you buy from crutchfield they know what you need and will supply that for free.
