Old Dec 16, 2010 | 07:25 PM
onehundred80
Default Re: Working on Engine/Things - Few Issues - Please Help!
Originally Posted by rcompart
Thank you. I can tell you with 100% certainty that you're holding the hood ajar switch connector. Why it's not connected I wouldn't have a clue. Good luck with it and sorry if I came across a little harsh. Just frustrating when you're sure you know the answer but you don't have enough info to be absolutely sure.
BTW, that first picture makes that connector look a lot larger that it really is due to the perspective of the shot and that's why I was having trouble identifying it and wanted a shot of it from the front.
Take care
Good one Rudy, I never did get an answer to the question about the wire running with latch cable to the front of the radiator. I guess that was it though.
Sometimes you get a bit frustrated with no info or not enough info.
The latch itself may have or may have once had a switch which would show a light or beep if the hood is not locked down properly.
Who ever repaired the car probably forgot to thread it through before the radiator was bolted into position.
