Old Dec 20, 2010 | 08:22 PM
32krazy!'s Avatar
32krazy!
Default Re: WTB: Shims for the 1st gen (?) C3 pulley
Originally Posted by oledoc2u
I have mine just one shim too close...I can stop the SC from spinning by applying pressure...but it will spin some, but not engauged...I think I will add a shim to not let it spin...but, I can send/lend you one to look for some, or try the one to get you tuned...either way...not thinking you are going to find these unless there is an MB dealer nearby...
doc you want it spin freely if its not engaged. adding shim will move the pulley farther away from the clutch. you want it close as possible without touching the clucth anywere.
no shims from m/b. they will only sell them as a replacement bolt washer pulley set. 1000$
mj i actually bought my c3 used from e/c. you might try jake or jerry and see if he has any spares laying around. at one time they had 4 pulleys. doubt they have any now but who knows?
