Old Dec 21, 2010 | 12:45 PM
oledoc2u
Default Re: Going to run the 1/4 mile needs some hints
Not sure if I want to....lol
practice will make you faster. you have to find what works for you. taking off the traction control is first and foremost, second is making sure you are in summer mode. Third, placing the shifter into 1st. Now the fun part, which is brake torquing the car. Some like to bring the rpms up high, some don't. This you have to practice...because now we are dealing with what tires you are running, air pressure, etc...all will play into that launch speed. Once you have figured out that majic rpm to launch, you bring the car up to that rpm, wait for the light, launch, once she shifts to 2nd, you can shift to 2nd, once she shifts to 3rd, you shift to third, and you will finish in 4th. Your foot should have been stuck thru the floorboard the whole time down the track...and it is what it is....once you see your time, you say to yourself....self, I need to go faster...and the $$$$$$$$$$$$$$$$$$$$$ flow.
