Old Dec 23, 2010 | 09:18 AM
patpur's Avatar
patpur
Senior Member/Moderator
Default Re: Remove plastic panel?
If 180's suggestion works for you do it that way. As I recall when you pull the bulkhead cover you also have to pull the rear, side window plastic trim mouldings. You have to be very careful you don't break the tabs on those mouldings doing that. I can tell you from experience they are about 20 bucks a piece to replace.
