Remove plastic panel?
Old Oct 13, 2020 | 12:40 PM
mariontr's Avatar
Default Re: Remove plastic panel?
If this is made from ABS/PC then you could use acetone to join it back together and use FG to strengthen it from the inside. Then cover it as mentioned earlier. Acetone liquifies the plastic for a few seconds while you realign it. A few quick applications is often required to get some depth of liquified plastic.
Hi onehundred80, thanks, what is "FG" ?
Old Oct 13, 2020 | 12:42 PM
mariontr's Avatar
Originally Posted by RED DOG
If you're not "missing" any pieces (and it looks like they're all there) then that is very repairable. This is the epoxy you should use . . . Great stuff . . .
Look here: https://www.ebay.com/itm/NEW-JB-WELD...QAAOSwYHxWOe8P
FYI - These get cracked and break when the seat or the seat back is run back too far putting pressure on them. When you get it repaired or replaced, be careful running your seats back . .
RedDog, thanks, just ordered a 3 pack from Amazon.
Old Oct 13, 2020 | 01:03 PM
It is not a magical solution, I have used it and it requires strengthening with a fibre glass or carbon fibre patch on the back surface without which it will much break easier than the first time and who wants to do the repair twice.
Old Oct 14, 2020 | 04:54 PM
mariontr's Avatar
Good to know
pesscadore7
Mar 11, 2020 09:35 AM
nickwe21
Nov 1, 2014 10:50 AM
FLcrossfire
Mar 21, 2013 06:30 PM
mrjazzmillcreek
Oct 28, 2011 01:50 PM
homer4evr
Jan 24, 2005 08:12 PM
