Old Oct 13, 2020 | 12:40 PM
mariontr's Avatar
mariontr
Default Re: Remove plastic panel?
If this is made from ABS/PC then you could use acetone to join it back together and use FG to strengthen it from the inside. Then cover it as mentioned earlier. Acetone liquifies the plastic for a few seconds while you realign it. A few quick applications is often required to get some depth of liquified plastic.
Hi onehundred80, thanks, what is "FG" ?
