Old Dec 27, 2010 | 12:16 AM
  #63 (permalink)
bmorgan's Avatar
bmorgan
Default Re: REVIEW and DIY - Lowered Rear ONLY with Pictures
Originally Posted by Fritzauf
You will need the spring compressor for the front springs only to do the job safely. I installed the Eibach Pro Kit and the ride is much smoother. I've also installed the Koni adjustable dampers. The ride and height is tight and just right.
I assure you that the job can be done safely without the use of spring compressors. Likewise, spring compressors in the wrong hands can result in an unsafe condition. I would agree that the compressors will make the job easier, and less time consuming, but safety is not an issue doing it either way.
