My plan is to purchase or fabricate a cable to mount on the same bolt as is now (create a junction without modifiying the original integrety), and run it over to a bell housing bolt or something easier once the engine cover is off. Another thing to remember, you should mount the cable directly to the block, cylinder head at the least, never to an engine bracket of any kind.
My thoughts
EXACTLY!
Pizza, look under the drivers side at the back of the engine/transmission. There is a braided ground wire from the frame to the engine. I like your idea of a good ground from the battery to the the block closer to the starter.
Thanks Mike!
